obd2 problem
Car  2010 Clio 1.6s
Hi everyone,
I have a 2010 Renault Clio 3 1.6 s and I am having a issue with the obd2 port.
I have a elm diagnostic tool and a heads up display that supports all obd2 compliant cars, but the heads up display can not read any information from the ECU through the obd port and the same is happening with the diagnostic tool.
If I use the diagnostic tool with a laptop I can connect and identify the ECU but it will not read any information like rpm or speed.
I have contacted Renault in south Africa bit they can't tell me if the port or ECU is locked or how to sort the problem out.
Has anyone had the same issue? And can anyone help me sort it out?
Thanks for reading
