OEM Top Mounts
  182, SQ7, Trafic
You need that bolt for it all to "fit". Unfortunately Renault revised it wrong and it DOES NOT FIT!
Plenty of threads on here.
Reuse the top hat bit, use the new bearing and rubber and the existing spacer and thin nut.
Craig
  4 wheels
Ah good old Renault Cheers mate will bear that in mind when I replace mine
  182, SQ7, Trafic
I don't know how after 3 years Renault haven't revised it again to fit.
If your replacing its not too bad but I went from solid top mounts to these and was a right nightmare!
