Struggler
Ph1 track 172
Is this a thing?
The way I see it the oil cooler will be dry. You can crank the engine to get some oil flow but with the thermostatic sandwich plate this is surely all going to bypass the actual cooler.
How do you prime the actual cooler core so it does suddenly open at a certain temperature and push the volume of air in the core through the system causing it to run dry for a few seconds? Am I worrying about nothing here?
