Right car is going in for its belts at Birchdown on the 18th (Feb) so Ideally if this is something like head gasket (although I don't think it is) I would like to know before then so I can get it sorted whilst the belts are off.
Basically a month ago I changed my radiator changed the radiator fluid my oil and oil filter. Refiled it with the proper stuff expensive valvolene jobby.
I also changed my digital oil level sensor for the dash reading as I thought it was faulty. (Now I don't think it was)
Checked the oil was all the way up to the top notch, fine good. "000000"
Now a month (and a bit) later the oil is half way between the 2 notches on the dipstick. digital reading "000---"
Now I thought oil leak !, can't find a sign of one anywhere. no oil on the garage floor etc. So unless it's dripping down the back then I've ruled that one out.
Next I thought head gasket ? But there's no black smoke ever and white smoke only on start-up on cold mornings like most cars... the expansion bottle also doesn't have any mayo or smell of oil.
Also the exhaust tip isn't excessively stained with unburnt petrol/oil.
The car will return 35mpg if nursed at 50-60 mph. Normally it is about 27-28 mpg driving around town, definitely worse than my 182 was on fuel.
Help !
Help !
