Theres no gasket and its a cam out job to reseal it as the cover has the top half of the cam bearing cast in it. If its just coming out the bolts you can try taking one out at a time putting some sealant round it and replacing it its a 50/50 chance.
Ahhh ok. Well in this case it seems to be coming from a number of bolts so its goona be an inlet manifold off job.
So just an engine sealant? Any brand you can recommend?
yh wip the manifold off, then clean the area around the bolt and just appile small amount making sore it covers round the hole circumfernce of the bolt
just get some high temperture engine sealent (worth RTV sealent) , sump sealent is very good one to use.
doesn't need to be anything special but avoid non-setting pastes like hylomar/hermetite red and blue. Remember to use a torque wrench on the bolts when re-fitting, 12Nm.
