No problem of pressure in F4R 832? Sure?You won’t need to do it on the 832 mate. It’s only the 73x series engine that needs.
It’s more harmonics that cause the problems like @bloke says.No problem of pressure in F4R 832? Sure?
What’s that in English mate? Lol![QUOTE = "NorthloopCup, post: 11707638, membro: 61663"] Sono più armoniche a causare problemi come [USER = 98854] @bloke [/ USER]. [/ QUOTE]
.... Allora cosa fare per aumentare l'affidabilità di F4R 832? .... Per eliminare queste armoniche?
Sorry NorthloopCup!What’s that in English mate? Lol!
Dynamically balance all the rotating assembly mate.Sorry NorthloopCup!
.... So what to do to increase the reliability of F4R 832? .... To cancel these harmonics?
Sorry![QUOTE = "NorthloopCup, post: 11708864, membro: 61663"] Bilancia dinamicamente tutti i compagni di assemblaggio rotanti. [/ QUOTE]
I trainer francesi dicono di aver risolto il problema della biella che sfonda il blocco posizionando le scanalature delle boccole principali sopra e sotto, viti ARP sulle bielle e olio 15w50 .... Che ne pensi?
We’ve been running full grooved bearings for ages mate. Lol!! Took them long enough to work that one out!! ?Sorry!
The French trainers say they have solved the problem of the connecting rod that breaks through the block by placing the main bushings grooves above and below, ARP screws on the connecting rods and oil 15w50 .... What do you think?
