OMG i want
  Turbos.
Do not want...
How about a V8 one instead? 1000bhp/ton isn't too shabby!
I'd be happy with an R500 though...
  Ph1 track 172
bet it wont be able to put that power down very well thou cause its too light.
but beeing that light would be very easy to move,
so it would even out,
plus your basically sitting on the rear axle, so i think a fair amount of that power would be planted lol
BIFCAIDS
  340i M-Sport & 182
R500 for daily driver for me lol gives a fook if you get wet lol worth it for having a Vayron slyer
Tullyvernon
Northern Ireland
  Williams, Focus RS
V8 one sounds good 2 me! 1000bhp/tonne would get ya out of a tightspot!
  Clio IV 0,9 Tce
What about this then?
Note: I grabbed all the pics and description off eBay to archive it here. Often I want to show these pics .. and I always have a tough time finding them in the old posts .. so I am reposting them here.
Rob Mitchell
Sugino's Custom Built Seven:
Lotus Super Seven (Caterham), Cosworth 2L BDP
Miles: 0
Year: 1962
VIN Number: AAV71338596A
Vehicle Description
1962 Lotus Super Seven (Caterham):
Custom built over the last 15 years with over 4000 hours of my time invested. This street legal car has a clear Arizona title, but has never been registered. This is a new car with zero miles. The car is very unique with everything polished aluminum, nickel plated, chrome plated, polished stainless steel, anodized aluminum or carbon fiber, but no paint. Nothing was spared during the build, only the highest quality components were used. I enjoy building cars and with this finished, it is time to sell it.
I am willing to sell the car without the engine (with supporting components) and or drivetrain.
Do not hesitate to contact me. Email me through Ebay and I will contact you as soon as possible.
Base Chassis:
1989 Caterham long c**kpit DeDion (new, never used)
Chrome Moly Roll Bar (chrome plated)
Nickel Plated Chassis
Additional Bracing
Body:
New Skin
Alloy Nosecone (modified)
Alloy Front Cycle Wings (widened 1" )
Alloy Rear Cycle Wings (widened 2" )
Alloy Boot Cover
Full Carbon Fiber Underpan
Carbon Fiber Tunnel
Carbon Fiber Scuttle Panel
Carbon Fiber Scuttle Tray
Carbon Fiber Interior Back Panel
All Panels Attached With Aluminum Button Head Hardware
Front Suspension:
Custom Fully Adjustable Wide Double A-Arms
Modified Large Spindle Uprights
Aluminum Hub
ARP Wheel Studs
Adjustable Sway Bar
Double Adjustable Koni 3012 Aluminum Racing Shocks
Adjustable Spring Platforms
Carrera Springs (chrome)
Full NMB Rod Ends / Spherical Bearings
AN Hardware
Nickel Plated
Rear Suspension:
Custom Uprights
Sierra Hubs / Carriers
ARP Wheel Studs
Adjustable Sway Bar
Full NMB Rod Ends
AN Hardware
Nickel Plated
Steering:
Custom Titan Aluminum Quick Ratio Steering Rack
Quick Release Steering Hub
Tubular Steering Shafr (Nickel Plated)
Alloy Borgeson U-Joints
Momo Steering Wheel
Brakes, Clutch, Throttle:
10" Vented Discs
AP CP2270 4-pot Calipers
Custom Aluminum Hats
Modified Tilton Pedal Assembly
Tilton Proportioning Valves
Scott Parking Brake (hydraulic)
CNC Emergency Brake
Stainless Steel Hard Lines
Teflon / Braided Stainless Steel Soft Lines
Girling Master Cylinders (3)
Girling Remote Reservoirs
Tilton 5.5" OT-III Twin Disc Metal Ceramic Rally Clutch
Tilton Aluminum Flywheel
Tilton Concentric Slave Assembly
CNC Hydraulic Throttle Assembly
Lotus Aluminum Bellhousing
Wheels, Tires:
Monocogue Racing Wheels (Custom) 9.5 x 13
Hoosier P225 / 45 D13 Street TD tires
Engine:
Cosworth 2.05L BDP (new from Cosworth Engineering)
Dyno Time Only
DA2 Inlet / Exhaust Camshafts
Piper Variable Cam Pulleys
Custom Stainless Steel Headers
Titan Aluminum Sump Pan
Cosworth Dry Sump System
Canton Oil Filter (6 micron)
Patterson Dry Sump Tank
Tilton Super Starter
Motec M4 Pro ECU
Wide Band Lambda
Wasted Spark Direct Fire Ignition
TWM 48mm Throttle Bodies
ITG Air Cleaner
Drivetrain:
Quaife Sequential 6-speed Straight Cut Dog Box
Alloy Maincase
Shifter Extension
(2.647, 2.012, 1.618, 1.337, 1.151, 1.000)
Sierra Differential (LSD 3.92:1)
Nickel Plated Propshaft / Driveshafts
Interior:
Tillet Carbon / Kevlar Seats
Schroth Racing 3" 6-Point Harness
Motec ADL 2 Dash
Interface to Motec M4 Pro
3-axis Accelerometer
Logging
Carbon Fiber Dash Panel
Electrical:
&C Aircraft Alternator
Linear Regulator
Over-Voltage Protection
Tefzel Mil Spec Wiring
DTM Connectors
MetriPak Connectors
Mil Spec Relays
Mil Spec Breakers
Mil Spec Switches
Master Switch
Lighting (5.25" Headlight)
Lighting (Lucas Indicators, Stop)
Misc:
Holley Fuel Pump
Bosch Fuel Pump
Canton Fuel Filters (1 and 6 micron)
Custom Fuel Safe Fuel Cell (12 Gal)
Kinsler Pressurized Vapor Seperator Tank
Griffin Custom Aluminum Radiator
Coolant Swirl Tank
Coolant Header Tank
Coolant Overflow Tank
Aluminum / Silicone Coolant Lines
Oil Cooler / Thermostat
SPA Design Carbon Fiber Mirrors
SPA Design On-Board Fire Suppression System
Electrically Activated
Nozzles (Engine, Fuel Cell, c**kpit)
Note:
Available at additional cost:
1997 NPR Isuzu
3500 miles
Custom enclosed carrier (built for this car)
Winch, Tie Downs, Ramps, E-track
