on cam
the clio has vvt and has twin cams is this correct? is there a noticeable point where it will pull harder? i dont mean if u can kinda feel it i mean similar terms to a civic hitting vtech?
  172, Tiguan
vvt is for idle, it will come on cams further up the rev range, forget where, after 4k
P.S, snooper arrived A.O.K at lunch today, cheers mate!
no such thing as on cam. There is no VVT on the clio. The advance is different at low revs up to 1200 or so to aid with idling and emisions, and then its exactly the same throughout the rest of the rev range.
  insignia
there is vvt and it works through the rev range up until 4,000 revs after that your on cam and it aint exactly the same coz it fuks off to the red line twice as quick and you can here it growl
  insignia
you cannot feel the vvt-its on cam where you can feel it, and suprisingly the civic didnt have the kick i expected it too have
vvt is on the car but it does not change the cam profile like vtec just changes the duration sligtly to smothe out idle and low revs due to agressive cams been used as standard (172/182 only as far as i know )
  Was a Clio 1.8 16v
Quote: Originally posted by Liquid_ICE on 24 March 2004
Around 4k ish
Similar to a Valver. Not as Harsh as the VTEC though I dont think
I think u have got the incorrect word there, u were looking for the word: good ;)
as I said before, and as dogmaul said, there is no "on cam" , vvt stuff on the clio - period - the advance is changed at low revs only to aid with idling.
  Revels Mum & Sister
Around 4k ish
By that I meant
Pulls like a 2 $ dollar all the way to the redline!
  clio sport 172
of course there is on cam, can u not feel it when ur cr gets to about 4k?? (unless u drive like a slug)
My cars "on cam" all the time. I drive like a slug on the road (well I try) and I take it on track about once a month. Nothing happens at 4k that doesnt happen at 3.5 or 4.5. In fact on track, I keep it between 5.5k and 6k where the power/torque peaks.
Before modifying the car, I do remember getting a power surge feeling between 4 and 4.5k, but that no longer exists now. Its just good throughout the rev range.... As I said above, I believe the 4k "surge" has nothing to do with cams, but has everything to do with the airbox second electrovane opening up and admitting considerably more air into the engine. So Im not denying that a normal 172 has that effect, its just got nothing to do with cams, thats all.
  Revels Mum & Sister
Ask BenR
He will clear the matter up!
On the VTEC doesnt it Open the valves a bit more. Letting more Air and fuel in!!! Hence the change in engine note as well!
Might be wrong thought it was something like that!
  TDI tyre shreader
There is such a thing as on cam as that is what happens at 4k... 1k nothing 2k....3k.....4k BAM, ON CAM, this is where the duration of the cams comes into play and the gas speed through the head is increased as the inlet and exhaust valves are just about open at the same time drawing more air into the chamber, happens at certain revs as rpm increase. hope this makes sense as beer has been playing :D
  2005 Nissan Navara
Variable Valve Timing, alters the cam TIMING (as the name sugests) at a set RPM. inlet cam is advanced so as to give more overlap and so dynamic pressure of exhaust gas leaving cylinder literally sucks in fresh charge--scavenging. at idle however (when butterfly is closed) there is a vacuum in inlet plenum. as gas speed is low at idle, exhaust gas tends to be drawn back in2 chamber (due 2 vacuum in inlet) and cause crap emmisions and idling--exhaust gas dilution.....Jones u were half right!!
Vtec-this system increases valve lift at set rpm. it uses oil pressure to operate a plunger which shifts from one rocker arm to another. the first having a lower ratio and so giving less lift, the second having a higher ratio giving more lift. more lift=better gas flow=more torque/power (and change in exhaust note!)
both systems give an increase in torque when they start to operate, often known as/refered to as on cam----personally i think its a bit of a gay statement!!!
  TDI tyre shreader
Isnt that off cam tho? hence the need for vvt so renault could use mad cams to pass emmision laws? i thought that vvt was only in use upto 1400rpm to improve idleing + emmision not to 4k, when it comes on cam :).
  2005 Nissan Navara
off-cam----less inlet advance=less overlap=better emmisions/idling
on cam----more inlet advance=more overlap=better cylinder filling=higher cylinder pressure=more torque
  TDI tyre shreader
Take it you are on about VVT, i read somewhere that it doesnt have any effect after around 1400rpm and that the kick at 4k is purely due to the cam duration/overlap not the VVT? Or is my knowledge of renaults crappy version of vtec all wrong?
The phenonmenon reffered to as comming on cam refers to the rpm level where inlet charge speeds are high enough to significantly increase the level of VE. So sorry to some, the F4R 7XX series comes on cam at about 4500rpm. its VVT mechanism however advances the cam anywhere above 1500rpm when at full load, dephases it when not on the throttle and on overrun.
The VVT system in the 172/cup advances the inlet cam 16 deg as stated via a pahse shifter on the inlet cam that runs of oil pressure (activated by a plinger solenoid ontop of the head), it does not alter lift or duration, just the timing of the inlet valve opening and closing points relative to the crankshaft position.
VTEC systems (ill limit my talks to the better and more modern 3 stage system as the 2 stage is old and no point talking about it) Use 3 cams per cylinder.
The high cam or big lobe is in the middle of the 3, and there is a less racey middle cam onthe right of it, and a low cam on the left of it. There is 1 finger follower per cam, so 3 per assembly, built onto an oil feed rail, which they pivot off, with 1 oil inlet. At all times each follower is tracing its respective cam lobe. At low rpm each roller is independant and only the low and mid cam is lifting the valve. Thus there is one low lift and one mid lift cam (duration and timing also alter with cam lobes). When rpm incrases the Vtec solenoid ont eh side of the head passes oil pressure through and a pin locks the low cam follower onto the md cam follower so you get 2 mid cams effectively, or its what the valve and cylinders see. At high rpm all followers are locked together via another set of pins in the lower part of the rocker, so the valves are running off the high cam in the middle only and the followers aret actually touching the low and mid cam.
This is the basic 3 stage Vtec, but cars like the S2000 with the F20C and the CTR with he K90 use a slightly different system where the low and mid cams are the same. The finger follower is also slightly different where teh cam is onto rather than below and is less complex.
VTEC is simply activvated by rpm only, not throttle position.
Toyotas VVTL-i uses both phasing and cam changing. The cam can pahse like a 172, and it runs 2 cam lobes per cylinder, and they swap between each other when the ECU decides, dependant on rpm, throttle position.
I have an S2000 head so if the mods/admin want im quite happy to do a full how it works with pics and the lot if there is enough interest. Even though its a Honda head and technology. Its rather facinating, since its all in peices.
No, you are quite correct
Ive noticed that at 4k it starts to pull but the moment it hits 5k it suddenly steps up to another level. It is quite a pronounced increase at 5k, but not as harsh as the vtec.
  Was a Clio 1.8 16v
Id say the airbox/filter will have a lot to do with the feel of when the power comes in.
I.e an original filter element will be more restrictive and give better torque at lower revs where an air filter will make peak higher in the rev range and expand the power band IMO.
Surely via the nature of flow, a higher flow element would give better torqure all round would it not. ;)
And i cant be arsed Chris, nobody wants it.
  VaVa
Ben mate, I would love to read it/see it. Never really had any interest in the internal combustion engine until I came on here. Theres a bit more to it than intake, compression, ignition, exhaust!! Im eager to learn!! ( go easy though!!)
  2005 Nissan Navara
oh please do ben, u will explain it to us wont u ben *c**k in hand tuggin furiously*!!!!
sorry, just messin!!!!!:D
Just cause you dont have an F20C head sitting next to you *c**k in stans hand spurting furiously*stan in gimp suit with that sooper gay dood off queer eye behind him.
Ergh:sick:
