One for the Technical Bods - OBD II fault codes....
Sash
Car  A Yellow One
Does anyone have any way of telling me what the following fault codes mean, as they show as Undocumented code...
01393
00051
00137 - this one was logged twice.
They were scanned using a Snap-On code reader.
one of those may be an air bag fault which I know about, as my seats aren't wired up!
Would be great to find out what its logged.
It was running particularly poorly up until I put some hefty injector (toluene) Cleaner through it and a tank of Shell fuel -- instead of crappy Tesco stuff.
FYI its a dCi 100.
Those codes mean nothing. You need to connect to a better scanner.
I take it you were connected to the engine ECU, if yes then the airbag codes would not be in there they are all in completly different computers.
Normally the reader says what the fault is, but for these it says undocumented!
It was just plugged in to the OBDII socket under the ashtray.
ObdII is the plug for all the computers mate. It's the main network interface
