One light works the other doesnt :(
  • Thread starter Thread starter Clio_Craig
  • Start date Start date
C
Clio_Craig
Just fitted some new bulbs for my headlights and just noticed that on one side the lil bulbs (sidelights) one works and the other doesnt, any one no wat the reason could be?? checked the bulb and its not the bulb, also the covers have dust in :( any way to get rid of this?
u might have negative with positive and positive with negative
so turn the bulb around and try that.
light bulbs arent polarity sensitive.. only leds.
how do you know its not the bulb craig? still does not work with the old bulb back in? if thats the case it can only be a damaged connecter/broken wire or possibly a fuse
Where did you get the bulbs from Mr. Regan? If its halfrauds, then you know why they dont work :|
i no its not the bulb m8, coz i took it out of the side that didnt work and put it in the side that did and the bulb worked fine, so not sure wat to do
