Open circuit on cylinder injector valve?
Car  clio 172 phase 2
Had my car on the diagnostic machine today as my cars running rough and the fuel consumption has plumeted this came up:
Open circuit injector valve cylinder 4?
Is my injector broken ?
Change injectors around and see if the fault changes cylinder. That should determine if it's an injector or not. If not it might be a driver error in the ecu but I bilieve they would go in twos so it's unlikely
depending on which diagnostics computer you're using, some still number the cylinders in the conventional manner and not the french way.
Sounds like dead injector to me though
Are there any variations with injectors ? Or are there one type for the 172/182 as u found some
On ebay for 35.00 and just want to check
