OK, Ive been scheming and I think Ive just about figured out the spec of my next install... will need to save up quite a bit for this one I suspect! Im aiming for an all-round loud SQ type set-up, so bearing this in mind any advice offered (probably mainly from EvilICE!) would be much appreciated.
Headunit: JVC KD-SH99R (which I plan to use with the amp defeat function for pure sound into the RCAs)
Amps:
Cadence Ultradrive Z777GD 1600W mono sub amp
Ground Zero Nuclear GZNA2600X amp
Ground Zero Hydrogen GZHA4125 4Ch amp
Mission Freeway 2Ch amp
Speakers: Pair Kicker Comp VR 6.5" midbass woofers in custom boxed builds on underside of parcel shelf running off 2 channels of GZHA4125
Pair of 5.25" Infinity Perfect components in rear decks (wtih Dynamat inside door builds) running off Mission amp
Pair of 6.5" Infinity Perfect components in front doors (again Dynamat inside custom door builds) running off remaining 2 channels of GZHA4125
Subwoofers: 2x10" Cadence Ultradrive UD10-4 (sealed enclosure) running off GZ Nuclear amp
1x15" Ground Zero GZUW15 Uranium series (ported enclosure) running off Z777GD amp
All running on 2 Yellow Tops with a split charge relay and 3 1 Farad caps (1 for each amp apart from the Mission), and with Oxygen wiring throughout.
Any opinions?
Cheers.
