There is, you either need an amp with speaker level inputs or get some RCA adaptors, I'm sure an ICE teccy will let you know more, all I know is that it is possible!
Yep you'll need a high level converter or get an amp that'll take high level inputs.
Did this in my mates punto for him and yep as above it sounds gash but if your dead set on keeping the standard hu for some reason then its the only way.
Theres another thing out not actually heard how it sounds but it allowa you to get same front rear sub preouts from a standard headunit but at the same time it costs as much as a decent aftermarket headunit and wont give you the better SQ from an upgraded headunit as they do make a big difference.
