Overclocking
mas
  MK7 GTD & Mini GP
I run a Intel Dual core 2.66ghz...
it idles at 19 degrees. wamt more power out of it?
what can i easily clock it to?
how do i do it?
thanks!!
T
thecremeegg
Need more info such as motherbaord, power supply etc, then i'll explain :)
mas
  MK7 GTD & Mini GP
asus p5k deluxe motherboard, 2gb twinx ram, thermaltake toughpower 750w psu
yeah, im power hungry ehehe
  None
up the fsb in the motherboard settings bits at the time until the computer wont boot first then lower it down by about 4mhz after it stops booting..
T
thecremeegg
Well i have a P5B motherboard, an e6400 @ 3.2Ghz (2.13 stock), 2Gb of OCZ and an 8800GTS.
I'm running a FSB of 400 and the RAM has 2.1V going to it.
Basically the easiest way is as has been mentioned, slowly increase the FSB from default, and test the stability. You will probably need to give the RAM and CPU more volts if you go fairly high, but the CPU only needs a tiny increase
  None
option should be in something named like "cpu settings" or something try going up about 4mhz at a time
get a program called cpu-z
I have an E6400 also but havent taken upto 3ghz, although i have read it can take upto 3ghz on standard voltage and cooling.
If you cant be arsed to change the voltage settings then i have mine running at 2.6ghz
Multiplier is set to 8
FSB is set to 333mhz as my ram is only 333mhz
If you have 400mhz ram then go straight to that and have done.
