P0420 fault code
Car  Clio 182
Car keeps chucking up the above fault code - catalyst efficiency below threshold bank 1.
A previous had fitted a different cat could this be causing the fault code? The car does not petrol on idle, also seems to be struggling when cold to accelerate, a new lambda sensor fixed this a a while back but it's returning I think :(
Pattern cats can cause a host of issues. However, many people run without cats on here without an issue bar the odd error code, so I would doubt it is the potentially the cause of your issue.
How do you mean that the car petrols on idle?
Thanks for the reply, sorry that should of said the car smells of petrol on idle and when you accelerate hard.
It had a lambda sensor replaced last year as it wouldn't rev over 2k when cold, that fixed the issue but it seems to be coming back again.
