painted door handles
Well you take off the doorcars and that means you have to take the interior handle, doorpull, speaker and winder off as well as the other plastic trim on the door. Then make a note of where the rod is in the handle, it has notches in it, count these and make sure you out it back exactly the same or it wont work. Then just 8 or 10mm socket will take the handle off, not too tricky really and if your careful you shouldnt break anything.
