PAS pump & Alternator removal & clio workshop guide needed
  clio 172
Do i need to remove this prior to removal of the engine ?
Got to fit a new PAS pump anyway once i get the engine on the stand
Will i benenfit by removing this first ?
Also anyone have a clio workshop manual they could send me please :approve:
Trying to do everythink from here.
fto_finch@yahoo.co.uk
cheers Guys
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
When removing an engine from a FF 172/182 I normally drop these and the AC compressor from the block as it does make life easier lifting the engine clear of the bay but it also means you dont have to drop the gas and fluids. It does add time to the job though but not much.
  clio 172
I removed the air con and alternator.
Ive undone all the manifold nuts but i cant get one of the bolts on the fixing kit, with the springs out from the the flange!
wil lthe engine and gearbox come out as one ?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Yep the engine and gearbox will come out as a single assembly without issue - just lift it at an angle so the gearbox comes out last.
  clio 172
Mick do i need to remove the subframe to get the 172 manifold off ? ive undone the nuts but obviously theres no way to slide it out top or bottom as i cant get one bolt out of fitting kit !
if i i drop the subframe does the steering rack need supporting or summit ?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
There should be no need to touch the subframe buddy - just unbolt the manifold from the back of the cylinder head and leave it till the engine is clear of the bay.
  clio 172
what about the wiring loom, ive disconnected the sensors from the block and also removed the ECU but i have the looms and fuse box relays all just above gearbox then it all seems to behind the manifold but i dont know if it can be disconnected as i cant see nothink !
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
yep, as above.... unplug it all from the fuse box, disconnect the ecm and out from above.
  clio 172
do you mean split the relay bases from the fuseboard or actually dissconnect the wires ? I havent looked into what can be done or can i unplug the relays and just split the bases from each other ?
  172/1.2/E30
There should be 2 connectors in the fusebox and you can disconnect the remaining wires from the main fuses aswell (take a photo of the fuse's positions for reassembly). Then there should be 2 wires from the alarm system soldered to the loom which you need to cut off.
