Paste wax gone like mush
  172
Just wondering if any 1 could maybe shed some light on to this the product in question is nattys paste wax. yes i know its a cheap product and theres alot better out there but it does for now.
It has gone quite mushy/watery after using it the other w.end
cheers
Loving that you presumed we would pounce on you for using nattys. I swear by it.
Is it stored outside? If so varying temps would be my guess.
  172
No in the house but it was a cold day when i used it.. Tbh i found it to go on better than HD and carnt fault nattys but you know how it is with some of the fellow members
Cheers 4 that JD
  Titanium 182
Natty's is brilliant, I've used it again and again! Left it in the garage before and it went all crumbly and basically couldn't use it again, but it was pretty much finished anyway!
Think JD is right, it's down to the weather conditions, whether it's too cold or too humid.
Cheers 4 that JD
I know. Toby is a b**ch and Don't get me started on that Gally character...
It should still be perfectly usable but I would be inclined to contact the supplier. Worded nicely, you might get a replacement, depending on how old the pot is of course...
You can still use it fella. If it goes like that scoop up a small amount and hand apply it, warming it in your hands first.
Temp fluctuations will alter most detailing chemicals sadly so indoor/temp controlled garage is a must.
  172
Was only the 2end time i had used it tbf and yeah il still use it
Cheers for the comments tho
Recommend any other decent priced waxes what give good results on iceberg?
I would stay clear of 476. Very dull wax and if longevity is all you're after (not looks) then go 845 insulator wax or fk1000p. Both will last 6 months if applied correctly and cared for.
Failing that, what's your budget?
  Not a 320d
f**king thankyou.
  172
Dont really have a budget in mind.. If it gives good results its worth paying the premium 4 wey thats how i think about alot of things
