Ph1 172 & Leon Cupra
Drove my ph1 to work the other morning all was fine, then went to move it at dinner and would not start was just cranking.
Had a quick look and found it wasn't getting a feed to coil or fuel pump when cranking so checked all relays and made a jumper wire to pump and coil but still no joy.
Removed the multi plug to ecu to check for breaks in the wires to the crank sensor with multi meter and didnt find any so plugged it all back together.
Then I just thought I would try starting it again and it fired up fine!
obviously I know its not fixed but question is what was it?
Im thinking a broken wire in the loom to ecu plug.
Any ideas would be greatly appreciated!
