PH2 172
As most PH1 172 owners will know, the OE items 8200027881 or reman 7711134954 (LH) & 8200027842 or reman 7711134459 (RH) have been unavailable for some years..
However shafts are still available from GKN & SKF.
These are the correct length for PH1 172 which had a narrower front subframe than later PH2`s, and are such are not suitable for 172 Cup.
Total length 640mm LH (fully compressed) & 734mm RH.
The GKN Spidan part numbers are 24688 LH, & 24689 RH.
GKN Lobro part numbers are 304959 LH, & 304960 RH.
SKF part numbers are VKJC3221 LH, & VKJC 3220 RH.
Various other brands are available, but GKN & SKF are name brands, and GKN was rumoured to be the OE manufacturer.
Prices vary wildly by up to £70 per shaft, so shop around.
These SKF shafts from Belgium is the best deal including UPS UK delivery I could find for SKF`s at date of posting.
https://www.energyparts-shop.com/en/fiche/124166/vkjc3220-driveshaft-kits-skf
https://www.energyparts-shop.com/en/fiche/124167/vkjc3221-driveshaft-kits-skf
This is a cross reference list with other manufacturers ( I cannot guarantee it is 100% accurate)
http://partinfo.org/spidan-24688/
If you require PH2 172 Cup shafts, they are available from Shaftec R209AL (LH) & R209 (RH).
