Just purchased a ph1 clio sport and all the fuse box and multi timer / uch box is hanging down has anyone got any pictures video of removing / installing or step by step guide
It is a pain in the arse, there is a guide somewhere will see if I can find it as bracket and how you move it not clear as loom so tight and need to remove the torx from under the little cover in the door shut also from memory. Tight as to remove as had mine out recently and maybe why they didn't put back in correctly
I seen a few faults on this forum that I think are to do with the uch so I thought this would help. The uch is a computer linked into your cars ecu, this controls things like wipers, lights, locks etc. There are a few common things that could point to the uch being faulty like lights behaving...
