Ph1 172 uch / multi timer installing
Hello all hope all is well!!
Just purchased a ph1 clio sport and all the fuse box and multi timer / uch box is hanging down has anyone got any pictures video of removing / installing or step by step guide
As not sure if any brackets are missing
Much appreciated
James
It is a pain in the arse, there is a guide somewhere will see if I can find it as bracket and how you move it not clear as loom so tight and need to remove the torx from under the little cover in the door shut also from memory. Tight as to remove as had mine out recently and maybe why they didn't put back in correctly
@rs_jim
