Ph1 Ph2 lights problem
Car  Clio 1.2
Basically, i have ph1 lights and replaced them with ph2 lights. I have put all the wires in the correct place etc. However my fog light wont work and now my right indicator doesnt, making the front one blink like crazy. I looked at the connections and there fine so any help would be great. Im confused.
thankyou
If your talking about the rear ones then you need to rewire the connector following the guide on here.
If you've done that and its still doing this you may have blown a fuse/no grounding/connections touching/normal electrical faults when mucking about with things
As above, having converted many I've never had an issue when following the guide that myself and fUbAr took time to make.
There are so many new guides coming like that ;), it's just taking me a f**king age! (sorry)
If you haven't changed the wiring, that's your problem, if you have, you've changed it wrong, it's as simple as that.
you dont need to re-wire them, making a simple job harder, keep the origional bulb plate from teh ph1 lights and on the ph2 lights, theres 3 plastic clips you can snap off to allow the origional ph1 bulb plate to fit in, works perfectly and never had a problem with mine :)
so is this standard ph1 bulb plate on ph2 lights? arent the rear lights different? on the top on ph1 bottom on ph2 i think im right in saying?
