I'm looking to change an injector on my ph2 172. I've removed the rail guard and undone the two bolts for the rail and unplugged the injectors. To get the rail off to I just need to pull it to pull the injectors out of the lower inlet or should I unclip the injectors from the rail and then remove the injector I want to change? ( the injectors are putting up some resistance so I don't want to pull too hard and damage anything ) I need to change the injector for cylinder 3 so haven't removed the fuel line if I can get away with it.
