PH2 throttle , significant delay
Hi, I feel like the throttle is delayed by half a second in my ph2 172.
If I floor it, lift the throttle very fast and press the clutch, the revs go up about 1K, although I left the throttle.
Anything I can do to fix it ? I'm not sure it's supposed to be this much delayed! This much delay seems to be wrong for a car like this, how should you drive on track, and do those fast little changes in throttle to balance the car with this much delay? Also it wears the clutch obviously if you aren't aware used to waiting some time before you press the clutch.
Also , it has a noticeable deadzone. The first 1 cm (about half inch) doesn't do anything. Any way to calibrate it ?
