Phase 1 172 bumper removal guide..?
The_Pirate
Car  Golf R
Before i go in blind and start breaking things... Is there a guide for this? I can't see one anywhere?
Cheers, Danny
The bolts on the wings, 1 each side iirc
The funny grill bit PH1's have, 2 torx bolts iirc
Then the under tray.
Been years since i did mine though. Dont trust me !
There's a 10mm in each wheel arch behind the s**t guard, 3 10mm underneath and the 2 torx at the grille, T30 iirc.
If it's for your wing you'll need to remove the side skirt too so charge up your drill and buy some rivets.
s**t guard? The arch liner?
Where are these three 10mm bolts?
A bit of clarity John please, you beautiful f**k.
Yeah the plastic arch guard at the front of the wheel arch. Those bolts are the most awkward ones.
The 3 underneath are in the middle then 1 a few inches each side, get down on your back as usual and you can't miss the nuts right at your eyes.
Aye there is, i gather the front two bolts on the undertray are connected to the bumper then?
Bit of a pain to do, but removed the bumper today to replace a OSF headlight on a Phase 1
Just thought I would add, that if you are swapping out a headlamp unit, you don't have to take both sides of the bumper off.
Just remove the 2 torx screws, and also (for me) the spoiler screws, as it got in the way of accessing the torx to move the arch liner to get at the main bolt
Then you have access to the 3 headlight retaining screws, and Bobs your Uncle (But you have to remove undertray bolts.
Managed it all in an hour b4 I went to work, which was handy. New headlamp from scrappers at £27 which seemed reasonable. Even came with working lamps.
