Pic request: Cold air feeds
Little Newms
  182, D2 Td5 & 840CI
I hope you have a good monitor...
Just about make it out
Brian
ClioSport Admin
  LY 220 Trophy
I just used some random gloss paint from halfords, resprayed after about 6 months due to stone chips..
Ali
  V6, Trackhawk, GTS
^ Can't do that on an RS
Cold air feeds to the bumper look s**t! And serve very little purpose, The maxogen or what ever you have required a constant supply of cold air, not a forsed supply. I had mine aiming at maxogen not conected, it ran down where the acoutic valve used to be and sat near the grill.
Gaz_
  Extreme mode
also when placed on the lower grill, the actual pipe needs flatting to get around the rad, useless imo
  VRS
had mine pointing at the airspace behind the headlight also, so it supplies air to the area where the maxogen slurps it all from
tested it out with a fan on the rolling road and you could feel the air coming up from the lower grill into the airspace so it does work :D
  ST
He's a real man...
