Plastic strips
  Mk1 MX-5 next summer
Is it hard to remove the side strips on a mk2 ph2 clio. I wanted to remove them for spraying them. TA:D
  Mk 2 Ph 2 1.2 16v
Think if you open the door, push the rear strip towards the front of the car, and the front strip towards the rear, they move a couple of inches and then can be pulled away from the car.
Not sure how easy it is though as I'll be doing mine in a couple of days
s**t duno y i put tht. mk2 ph1
haha, am sure its same. Good luck with ures. where u get paint code from
  Mk 2 Ph 2 1.2 16v
If you look inside the drivers door on the VIN plate sticker, I think its the third number down on the left hand side. Should read something like NV followed by three numbers, eg my paint code was NV603.
