please please help!!!
  clio 172 cup
can anyone give me a definite answer to locking my 53' plate 172 cup without setting the alarm
the bloody thing has a mind of its own at the minute and its starting to get on my wick,
the boot has no key lock, the drivers door has no key lock, but the passenger door has key lock but it doesn't lock all the doors and boot like the button does on the key,
it started going off from extremely loud cars going past but now just randomly does it maybe once every few hours or every couple of days depending in its mood
i will just remove it when i get time and if its possible but am just looking for a quick fix for now
PLEASE HELP SOMEONE AS MY MRS AND NEIGHBOURS ARE NOT IMPRESSED
only option i could see would be to lock the rest of the car from the passengers side using the button on your dash strip (with your passenger's door open) then shut and lock your passenger door?
give that a try and do the reverse to unlock the rest of the car... and obvs check all locks
-J-
  RS2'ed 172 Cup
Key in ignition, switch on and off 3 times exit car and lock as normal. Car should beep to tell you internal sensors are off.
Walk away
  clio 172 cup
cheers for the replies, thought i tried both options yesterday but must have been doing something wrong as just been out and now the car is locked and fingers crossed QUIET :)
cheers for the help
Sam
North East
Walk away
Isn't it just turn off, turn twice, then take key out.
I may be wrong though..
