Plug, Leads, Airfilter PH1 172 recommendations
  Clio 172
What would you guys recommend for plugs, leads and an air filter for a PH1 172? Anything that anyone has used that is particualrly good?
Thanks Andy
  Clio 172
I just bought a pipercorss airfilter after reading Mr Bone's review from fastcar.
No benefit to be had from uprated leads then? Dual core etc?
  Clio 172
Thanks Fred. I went for the airfilter as its washable and would save money in the long run. Did those braided lines ever show up? My arb arrived last week at last so might have a try at that this week, Got the jack and stands all set up just need to support the bottom of the suspension with the jack to get the desired setting for the arb I believe you told me.
  Clio RS 172 /Trafic
I use a green cotton air filter in the standard 172 air filter housing. It works very well. I uprated the leads to magnecor performance leads.
