They are still on the car as I've just bought it yesterday.
I had them split and polished/ painted by 'Mike the polisher' 4 years and they were like new but don't really want to send them away to be done again just now.
Is the outer rim bare metal or lacquered? If it's lacqut then metal polish isn't needed, just any normal paint polish. If not autofinesse mercury or autosol.
As for sealing, get the prep right and look into GTechniq C5 or Carpro DLUX
I would avoid clear coating them. They will 100% start to corrode again and then you will have a bigger problem as it will be under the clear coat. Best bet is to leave them bare, i ran bare ally dishes over winter and the dishes stayed pretty good with just Autosol, a hard wax and regular fresh water washes. Long term save up for some Radinox dishes.
it depends on how bad the corrosion is, if it doesn't take to much to get back to a good base then clear coat them. A did it to a set of wheels that were fine for almost 2years then sold them on. Planning on doing it to another set this summer
100% will corrode isn't quite true. As everything its based on the prep
This was the wheels when i got them re finished and the centres done black.
If they can be lacquered then I will do that after a re polish, but I was under the impression that you can't as the surface is too smooth to take the paint.
