Dont test me boy, worked for renault place and my boss did that, day in day out, 12 year reno master tech@Doobury ^that's not right. You have to get a matching set; ecu, key fob, decoder ring and uch. A UCH can only learn if it's vigin. Don't worry about the part number so much but make sure it's whatever comes out of yours in terms of the "N" specification. If your car has a rain sensor it will need to be an N3 kit.
i have the right attitude, saying the right things.. PeaceJolly good. What a bizarre attitude you have to helping people
hi the window is going down and then randomly not going up,makes a relay sound when trying to push it up,if i shut the door while pressing the key fob on and off the window goes up?meh
If you can teach us how to relearn a second hand module that would be very helpful to a lot of people, me included.
Regardless. It would be cheaper for this chap to buy a replacement kit if the UCH were to blame. You can just reconfigure the UCH for the various functions of the car depending on spec but it would be best for you to get one from a car which matched your trim level.
Does the window go up and down or not? The UCH of course controls the windows so you do expect to hear a relay sound when using them if you really listen for it.
I thought that was the only way Mike! You can't relearn and old one though is my understanding.Only way to fit a used one is to remove the chip off the used unit and put the one from your original unit.
It's only a surface mount chip and if your anygood with a soldering iron should take around 20 to 30 mins to do.
Done loads of them with around a 90% success rate.
Sounds like it matey. The windows work by reversing the polarity to the regulator so it sounds like that isn't working properly. odd!hi the window is going down and then randomly not going up,makes a relay sound when trying to push it up,if i shut the door while pressing the key fob on and off the window goes up?
Unplug the regulator and test the voltage going into the motor. If that's okay then could be the reg.everything else works fine could it be the regulator
