Are you looking for good quality, decent priced spare parts?. If so - you are in the right place. We will do our best to resolve the issue asap. OE reference: 8200207049, 8200028797,0280158226, IWP042 (for comparison only).
williams-ant said:
I did, first thing I did. As above though, one of the new injectors that I fitted turned out to be faulty!
[/QUOTE
nice one
wish it was that easy for mine ..... checked new and old injectors ... all showing 15+/-0.5 ohms
@ Bashracing .......
I have checked the compression it's 180/195/180/180 for 1,2,3,4 ..... tested with all plugs out running engine on starter motor until the gauge maxes out
I have checked and swapped around the plugs (fairly new)
I have changed the coil for new
I have changed the HT leads for new
I have changed all four injectors for new
I have swapped the O2 sensors around
nothing seems to fix it .......
=> flashing engine warning light ..... only at low speed/stop/start .... goes off during any continuous use after a few minutes .... no power loss at any point
error message is alway 'misfire cylinder 1'
Well for completeness ... in case someone comes back to this thread .... The car if fixed for the price of an inlet manifold gasket !!! seems there was a small leak, that was enough to confuse the electronics at tick-over with no load ...... IF you have the same problem it's a lot cheaper to start with this than injectors, etc.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
