Possible Gear box problem ?
  Clio 1.2 16V 2003
Hello Guys
I had a strange problem in the car during last 5 months......its a 1.2 16V ph2 2003
I usually begin to drive the car when the engine temp is optimal and when driving slightly I feel a slight knocking under my foot and when I begin to accelerate hard the knocking becomes worse and loud and the whole car is hesitating.......the strange thing is this problem disappears after driving the car for about 15 to 20 min and the car drives very smoothly without any problems
I changed both drive shafts and still problem exists and I'm beginning to think that it is gearbox problem as when gearbox oil begins to heat up the problem disappears
I changed the gear box oil last night and will see next morning if this problem still exists
Any help or suggestion will be appreciated :approve:
  big boost cup
They are rubbish when cold. I'm having a similar problem at the moment but the knocking is still there when warm
  Clio 1.2 16V 2003
This morning problem disappeared
As I thought......last night I changed Gear box oil with a thicker one, the original oil is 75W80 and I put 80W90 and I hope this solved the knocking issue when the box is cold
note: last night when draining the old oil it was very dirty and was very light.....I think it lost it's viscosity
  Clio 1.2 16V 2003
Hello everyone
OK....since last post ( 10 months ago ) I changed the gearbox oil with a thicker one ( 80W90 ) to avoid the knocking issue when the box was cold and it solved the problem
Now it began to appear again also when the box is still cold and after 20 min of driving it disappears and everything is fine
I also noticed that when I release the clutch from first gear or reverse there is a knock like sound or clonk from underneath, before this issue this sound was not very noticeable, but now it is very clear and loud
As you know from my first post, I completely changed the whole both drive shafts and recently engine mounts and dog bone, I guess all these signs are the beginning of a Gearbox worn or failure
In the mean time I'm going to have a clutch kit change......should I consider finding a Gearbox in good shape from yards while the mouth is open ?? :D
Thanks for your help
DaveDreads
A loud knock or clunk is usually mount related,
I only got rid of my clunk completely when I polybushed the dogbone
and fitted K-Tec (vibra-technics) engine and upper gearbox mounts.
  Clio 1.2 16V 2003
Thanks Dave, I doubt these mounts would be available in my country, I think I can get used to live with this problem
OK.....any ideas about the signs of the gearbox getting worn ?
  Clio 1.2 16V 2003
Hello Everyone
New updates......
I have managed to find a Renault dealer that imported a whole lot of brand new 1.2 16V D4F engines with their Gearboxes ( JB1-513 ) from a faced out product line of Renault factory which ended up in their stock warehouses
I have checked the engine myself and believe it or not, coolant hadn't enter these engines and gearboxes are brand new
I bought one of these engines with it's gearbox ( without accessories ) and swapped it in my Clio......WOW...I remembered the good old feeling of a brand new car :clap:.....everything just went fine and the car is great and horse power is awesome and shifting is brilliant.....but....
I noticed that the same old symptoms of the gearbox slight knock under my feet in the morning when the car is cold and after driving for 15 min. it disappears and everything is fine......the oil I used in this new box was Valvoline GL4 75W90 and as I know 75 is good for cold starts and shifting
OK....what am I facing here ??? :S .....I really am very confused and don't know from where to start investigation :(
A year ago I changed both right and left drive shafts with their CV joints....I think the brand name of these shafts was ANKA and it's made in China :quiet:......could these shafts cause this issue ???
Kindly help and advise as weather is getting colder these days and it takes time for this knocking to disappear :(
  Clio 1.2 16V 2003
No, it's nothing to do with bodywork or exhaust system
I forgot to mention something very important in the swapping procedures
My gearbox version was the speedo version that had the speed sensor in it, but the one I purchased was the non-speedo version ( JB1-513 )
Solved this issue by swapping the right side casing of the gearbox with my old casing that had the speed sensor opening
OK....swapping was successful and was a piece of cake conversion
After doing some searches on the web, I found similar symptoms of my knocking when the box is cold and turned out to be bad pinion bearing, as the box warms up the seal expands and doesn't allow the drive shaft to play and knocking stops
As you can see from the pic below, the right housing of the gearbox has the pinion bearing in it, and not lucky me
:(....I took my old housing with its bearing and thought it was just a metal casing and totally forgot the bearing issue :cry:
The Red arrow shows the pinion bearing
The Green arrow shows the place where the speedo sensor should be installed ( that was disabled in this box )
The Red line shows the right housing part from the left housing part of the box
OK....I think the problem is getting clear hear cause this is the only part in common between this swap
Can this pinion bearing be replaced without getting the box out or I'm facing a nightmare :eek:
Any suggestions will be much appreciated :eek:
