Digsey
182FF
I need help with my 1.2, i recently replaced the rocket cover gasket as it was leaking oil over the exhaust and generally stinking up the place.
Whilst i had it apart i also cleaned the throttle body and removed the pool of oil that collects in the inlet manifold on these d4f engines.
after ive put it all back together the car is running very lumpy, and it judders and sounds like its splutting and misfiring when accelerating from a stop but runs fine once its over 2000rpm
also the idle now seems to cough and the whole car judders every now and again, am i right in thinking this is a misfire? there are no warning lights on the dash and no codes stored.
the plugs are under a year old, and it was running perfectly before i took it apart to fix the oil leak, could i have damaged the leads or coilpack when i removed them? or is this likely to be an injector fault?
any help would be appreciated
thanks
thanks
