PH2 Clio 172
What sort of RPM range do you find you get the most performance from your Clio? If you were racing on track when would you change gear?
no point in running right up to the limit in every gear.
NOOO! you have to on the track! not 1st tho..I would say 5k+ then change at 7.....no point in running right up to the limit in every gear.
Not always true on track. Sometimes you want to hold on longer to avoid upsetting the balance in a corner. Some people run 7800-8000rpm rev limits for this reason, as it gives greater flexibility.
