Jack!
How does one power two headunits? I want to power the double din in the dash and a single din in the glovebox. Can I just splice the wire for power on the quadlock/ISO and send it to both units?
I doubt it mate as a headunit will pull much more current than a camera.The manual says the Camera Out cable from the Android unit is 12V, so that's fine for powering the HU in the glovebox?
Yes, and no.Sounds like a right faff. Can you not just get a better quality android HU instead of having two working independently.
Yes, and no.
I want the OEM look, not a Pioneer in a fascia, hence the hassle.
Something like this?Is there no other unit from the VAG group that will work. At least it’ll be practically OEM.
But that's not a genuine item, so will probably have exactly the same problems the unit I'm trying to use has.
That will work for the Pioneer I've bought but not the Xtrons because it doesn't use that standard 8-pin style plug.https://www.ebay.co.uk/itm/Audi-TT-...h=item3fb34e32ef:g:OcgAAOSwBMpb7yZr:rk:5:pf:0
https://www.ebay.co.uk/itm/LATEST-A...=item363addf15d:g:fr8AAOSwr~lYsDuH:rk:22:pf:0
https://www.ebay.co.uk/itm/2007-201...h=item4b552450f8:g:eD0AAOSwCVtb7S7h:rk:3:pf:0
Even the audi units are just standard double-din units with a fascia plate. ?
Your BOSE / aftermarket unit problem is solved with this
And I appreciate.Well, I tried.
