Powersteering Flushing
Car  Cooksport Fleet
On a mk 2 ph 1 1.2 where is the best place to flush the powersteering from.
Friend of mine thought that tank was the windscreen washer tank... lol!
when i took mine off wen i put a new engine in it was a nightmare to put it back on the rack so i would sayt at the pump and just run the engine t get it all throught then when you fill up its like your coolent it will go down once you run the car so keep it topede up dont quote me on this im not a mechanic but mine seems to be fine
make sure you tun your wheel lock to lock when draining and when topping up
to release any air pockets
an to fill the sysem
I need to take it off at the lowest point i think.
But i have never even looked under the bonnet of it.
just follow he pipe running from the pump an disconnect it at its lowest point.down by the front right hand side offside
