problem accelerating
over the weekend my mk1 clio started stuttering when accelerating, i can only describe it as driving against super strong winds, sometimes it accelrates fine, others not all, or its stutters and the power delivery isnt constant. I find it isnt as bad if i lift off and accelerate again but after a few seconds it starts happening again. another way to describe it is as if somethings blocked and air cant get through. also happens when parked in neutral, sometimes it will rev up fine and reach top revs and others it will struggle and bounce back and forth between revs while slowly decreasing. any ideas?
If I'm guessing what you mean correctly then perhaps its misfiring? I had a similar predicament on mine. Changed the spark plugs and all was well...
Change spark plugs / could be worn or incorrectly gapped
Change fuel filter / could be cloged
Do that first, if no joy then it could be>
dodgy ignition coil
Fuel pump could be faulty
faulty HT leads
vacuum leak someware
fuel pipes fucked
But hopefully not...
Also put some injector cleaner in for good measure
Ps, are you sure the brake(s) are not binding and that your cluth is not slipping?
