RB FF 182
Hi All,
Told you I'd be posting again before long!!
I've had this problem since buying the car over a week ago, and it doesn't feel to serious.
Here is what is going on;
Kwik Fit checked the tracking, and informed me it was spot on. They said that my track rod ends were stiff. My mechanic informs me that they're meant to be stiff??? I NEVER listen to Kwik Fit in terms of repairs because I know what they're like!
Also, the brakes aren't as sharp as they should be, it had new pads and discs not to long ago so I'm going to be having the brake fluid changed.
Sorry about the essay, has any one else experienced this problem?!
- The steering wheel has to be turned slightly to the right at all times (tracking is spot on, and has almost new tyres all round, directionals at the back and normal tyres at the front)
- The car steers slightly to the right most of the time, if i let the car drift to the centre of the road, when it touches the right line it turns its self back to the left, not violently.
- If you go over a dip in the road, like where a bridge is joined to the road and the entire surface becomes lower (when your doing 30ish) the wheel subtly pulls to the right.
- When on rough road surfaces the steering feels very loose, and gently pulls left and right, but more so to the right.
- Sometimes, when gently braking, the car moves to the right.
