Problem with the warning lights
Car  clio 182
I just bought a 182 (2004)
Yesterday when I was driving in the motorway the service and antispin warning lights came on. (the car was serviced 1500 milies ago)
I stop the engine and when I swich it back on they were gone.
That happends once again.
What it is wrong ? Shall I worry?
Re: Problem with the warming lights
I have had the service and ESP lights come on before, all i did was adjust the brake light switch(common fault) and all has been well so far.
Unlily to be the brake light problem that was usualy fixed early in life.
Need to get Renault to check the fault or a garage with the tools.
I wouldn't worry unless it happens again though.
yeap happend again yesterday same story I switch off the engine and when I switch it on everything alright!!!!
You need to get the error code checked realy might be a sensor problem most likly by the sounds its the one by the handbrake.
i had this problem, and it was simple to fix, my brake fluid was low, toped it up and it hasnt done it since
