Prolonged beep when I lock the doors
Hi
Just got my Clio back after having some work done (cambelt, dephaser pulley, plugs, oil change) and now when I press the button on the key to lock the doors, they lock, hazards flash and then it beeps continuously for about 30 seconds
It didn't used to do that. I occasionally got 3 shorter beeps but never a 30 second continuous one
I've tried locking/unlocking with both keys. The doors do stay locked after the beep it's just annoying :S
Any ideas?
Sash
  A Yellow One
Means a door or bonnet is not closed properly.
Check the bonnet alarm switch
  Megane dci 130
It means there is still a door or bonnet open. The only thing they would of touched would be the switch on the slam panel for the bonnet. Check that is plugged in.
Think I've sorted it now after the alarm going off 10 times :eek:
There was some kind of plug thing on the right side of the front (just near the Renault badge) that must detect if the bonnet is closed, it was sort of hanging out. Pushed it back in, closed the bonnet and locked it with the key. No beeps.
Thanks guys
