Quick computer question....
Sheila’s’ Wheels’
  Whichever has fuel
My camera is now having to be plugged in via the USB lead.
(My card reader is kaput) what is the camera now under when i am searching for it? ie C drive, local disc, desktop etc
Can't find it anywhere.
Marky_
Depends on the camera i think.
Would have thought it should show as a new drive. If not you might need to install the software provided.
  Bus w**ker
I'm assuming Windows. If so it should show as a removable disk/device. I'll go as far as saying it won't be A: C: or D: but it really depends on how many hard drives you have installed and CD/DVD drives.
Are you sure the USB has been registered by the OS when you plugged it in?
iimushroomzii
Toilet roll king
  Transit Connect.
Should come up as removable disk, normally get a pop up the first time you plug it in saying new hardware found.
Sheila’s’ Wheels’
  Whichever has fuel
I plugged it in and it said it was installing, then flashed up that it was installed succesfully.
I'm trying to put some pics on photobucket. :(
  1 Series Coupe
Try unplugging, then plug it in again. If not, try another USB port.
Doesn't need any silly manufactures software installed does it?
  DCi
I would advise you to try and find the make/model of your camera and try and get the appropriate software/drivers
look for serial numbers on the bottom etc and stick them in google if youre really stuck
Don't know too much about cameras but if that doesn't work you might need to invest in a card reader
