R.A.I.D door lock system on mk2 ph1 help!!
My mk2 ph2 comes with it. All you do is hold the door lock button in for a few secs till you hear a beep sound. then drive over 6mph or so and the doors will lock automatically for you
^^ thats how I found it, was sat in traffic so thought I'd have a read. and thought f**king hell that sounds cool, now its alway on!! never be too careful.
people always say why do you have that on, well why the f**k not, I dont want people opening my door if I dont want them too, its not exactly a hinderence.
i pressed mine down, the doors lock then unlock and the led for the immobiliser stays on till i start the ignition or 10 seconds and doors lock and unlock again
With ignition turned on press the door locking button for 5 seconds and you will hear a beep . When you set off the doors and boot will automatically lock when your speed reaches 4mph ( 6kmh ) and the red light on the button will illuminate .
To deactive R.A.I.D repeat the process ,hold in for 5 seconds with the ignition on .
In the event of a crash the doors will remain locked .
fUbAr said:
you sure about that?
i thought they unlocked on impact?
Yep , sure about it . Its says in the renault manual that if you have the R.A.I.D set to auto " in the event of an emergency it may be more difficult for those assisting you to gain access to your vehicle " .
yes i hear them, and the button goes red, but then it unlocks automaticly about 4 seconds later?
tom
Sounds like you should get it looked at if your really that bothered . You could always lock in manually with the button .
