R.A.I.D
Does anyone have any info on the 172 security or at least a link to RAID on a manufactors site??? Have searched all forums...
Cheers.
Andy
  Clio II 1.4 Priveleg
R.A.I.D Renault Anti Intruder Device! Kool name init!
RAID will automatically lock the vehicles doors when a speed of 10kph / 6mph has been reached. It can be enabled or disabled by using the following method.
1. If its already switched on, then your doors will lock soon after moving off. To turn RAID OFF, switch on the ignition and depress the central locking button until you hear a BEEP. Thats it!
2. If your doors DO NOT lock when driving off, then with the ignition switched on, depress the central locking button until you hear a BEEP. Thats it, now switched on.
Also, for those of you with AUTOMATIC headlamps, this function can also be turned OFF/ON. With the ignition switched on, turn the side lights ON/OFF twice fairly quickly to enable/disable.
Hope that helps.
Bob RTE
