KTM 990 SD / S60 D5
Is it ok to run r888s the wrong way round for dry use.
Why???
I'd imagine he's worn the shoulders out and wants to get a fresh edge in place.
Yes mine are very much like this, but on the assumption its for track use and he's burned out a shoulder IMO i dont see any dangerous problem from running it backwards IN THE DRY.
The purpose of the physical tread lines is to dispel water to prevent aquaplaining, the rest of the tyre IE the smooth black stuff is what grips a dry road and the rules of physics for grip between rubber and road works in both directions.
Never seen slicks with a direction of rotation... :nono:
If they are that bad then run them as slick the right way round instead is the same diffrence if it's dry then surely?
If it's for one edge being worn, just get them swapped over from left to right.
This.
+1.
i thought this as soon as I saw the title. Why mess around with changing the direction when their rotational!? Probably don't matter if their run the wrong way in the dry but you have to take them off anyway to change them around backwards. Plus if you did run them backwards and it starts raining....
avon track tyres on the catherhams work better backwards bizzarley, causes all manner of moaning from the competition though LOL!
