radar detector query
buying a snooper detector for my 04 cup and was wondering if there are any problems as it mentions reflective screens. any advice welcome.
  172 GTR
Cups dont have a reflective screen mate, so you will be ok.
Go for a Road Angel 2 if you can afford one!
  172, Tiguan
Probably best you use the search, this has been discussed loads of times and youll get more info that way. But yes, there is a chance theyll be a problem.
Has
  RS 182 - Black Gold
in a 182/172 or even any new clio with reflective screen
You have to place the RA2 in the squeare cut out in the middle lower half of the screen
If it is not placed as far back as it can go, then you will have problems with reception.
In most cases i have found after installign them they are OK, but most people prefer to purchase the extra re-radiating antenna to make a 100% sat lock.
M.C..
if you have air-con in the cup then you will have a problem (IIRC you only get a relective screen with air-con)
ive got a B2 and have fitted the gps reciever by the back window works fine there
