rear axle spacers?
  AAS'D RB 182
Was thinking about putting some camber shims on my 182 and at the same time putting some spacer shims in. Are these a good idea or not? will they cause any damage? cheers guys any advice would be great?
  AAS'D RB 182
Re: rear axle spacers????
yes mate just like those but also some say 6mm or 8mm spacers to widen the track. There was a guy on here selling some abit agojust wondered if they were any good?
  Clio Mk2 Ph3
These are mine
Made from, aeronautic aluminium 7075!!They offer, -1 30' and -1 50'.They are about 2mm on the edge and 4mm at the bottom .If you find a person that can do it, make them thicker(your choice how) and sign the right angle you want, for the camber.So,you will not need,camber shim and spacer.2 in 1;).
  AAS'D RB 182
cheers guys. well one off the companys i work for are a going to make me some up so will let you no how they go.
