rear brake discs
  2002 172 sport
hello people just a quick ? should rear brake discs be the same width as the front discs a friend of mine who knows a bit says it's unusual that a sports cars (172)rear discs are so thin.also dangerous.i think there standard but not sure.its due a service so maybe i need to have this sorted cheers.????????
MRBILLYUK
  FF Jeden Osiem Dwa
Rear discs are 8mm new on 1*2's iirc and 7mm minimum thickness .
  2002 172 sport
cheers for that so they are supposed to be thinner than the front discs.as my front discs are twice the thickness???
MRBILLYUK
  FF Jeden Osiem Dwa
Yep , rears are only very thin . Fronts are vented 24mm new , 21.8mm minimum thickness .
  Clio Sport 182
most makes of cars usually have thin rear disc's as they dont really brake on them, unless you go high performance cars.
Martin_172
yep much thinner on the rear as they are solid disks, no need for vented rear disks on the 172/182, or most small front wheel drive cars for that matter
