Rear FK shocks a bit "crashy"
Can I just upgrade these to Koni adjustables? If so, how much is it likely to cost for a ph2 non sport?
Fronts are fine, and even better now the AST top mounts are helping them dampers out mahoosively!
Cheers for any thoughts.
Jamie
Cool, how much Jords? And do you think that is going to help, or is it going to be the springs?
I doubt it will be the springs, they dont tend to make it go as you're describing, it could be shot dampers with being the height youve had it at for a quite a while...
are there any leaks or signs of leaks on the dampers?
Im not sure where you can get them from as seperates though...
they many not be shorter on that page, like the ones you need (your shocks are shorter on coilovers than standard, so you can go lower)
just look for any leaks around the shocks themselves
Ok cool, will do mate, any ideas on where people get them from in that case, or am I better going for replacement FK ones?
